Orbi WiFi 7 RBE973
Reply
RBK752 work as router for Frontier FIOS 500/500?
dale_ander
Follower
If I purchase the new Orbi AX4200 Tri-Band Mesh Wi-Fi System (2-pack), model RBK752-100NAS, will I be able to use the router as the router for my Frontier FIOS instead of Frontier's?
Any compatiblity issues?
Will I be able to just plug the input ethernet cable in to the Orbi router that's currently plugged in to the input port on the Frontier Router and things will just work or is there some special configuration I will have to do?
Thank you
Message 1 of 2
Guru
Re: RBK752 work as router for Frontier FIOS 500/500?
Someting to ask the ISP about first. Some ISPs either require there own router to be used or special PPPoE account information to be used which if this is the case it maybe possible to input this into the RBR and use it has the main router. Again, please contact your ISP and let them know what your wanting to try.
Also you have other options with ISP owned routers:
https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1053 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
