Orbi WiFi 7 RBE973
Reply
RBK753 Wifi Speeds
LBX5JK
RBK753 Wifi Speeds
Set-up
Sky Gigafast product installed to the house. (900Mbps)
Sky Hub 4 (SR203) connected via CAT6 to ONT.
Netgear ORBI RBK753 (in AP Mode) connected via CAT6 to Sky Hub 4.
x2 Netgear ORBI RBK753 satellites successfully deployed with 'Blue' LED, confirming 5GHZ connection type to Router
Speed Test
Results of both a Wired Speed Test (connected to ORBI) or via ORBI App (iOS) confirm router speeds of 800Mbps
Running a Speedtest from devices connected via WiFi to either satellites or router return speeds ~200Mbps to 400Mbps
Question
Are the WiFi speed test results 'good' or should I be expecting closer to 800Mbps?
Message 1 of 4
Guru
Re: RBK753 Wifi Speeds
What WiFi devices do you have connected for speed testing?
Message 2 of 4
LBX5JK
Variety of apple devices (iPhone 12 Pro Max and 2021 MacBook Pro)
Message 3 of 4
Guru
Ok, I have a 12 pro max as well though MBP is only 2018 so no AX on it.
• Orbi AX4200 Router and AX4200 Satellite
(600 + 1200 + 2400Mbps)†
1200Mpbs on 5Ghz so nearest you see is around 400-500Mpbs while nearest the RBR.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 516 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
