× You're Invited! Orbi RBK763 Beta Firmware Testers Needed. To participate in testing this trial firmware, please click HERE.
Reply
RBK753 Wifi settings
rossy100
Follower
Hi all
Just upgraded from RBK53 to RBK753.  Speeds seem improved so far.
What are the recommended wifi settings for this? (20/40 coexistence, WMM, CTS/RTS threshold etc.)
I couldnt find any post on this, but happy to be pointed in right direction!
Thanks
Message 1 of 2
Guru
Re: RBK753 Wifi settings
Leave them at default. If your confident that your system will work with all of your devices well on 40Mhz only, then you can change this.
CTS has a new default of 64 which NG recommends using. Some users have experienced connection issues. So you can change this to 2347 to test to see if this resolves anything. WMM should always be enabled.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 345 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
