Orbi WiFi 7 RBE973
Reply
RBK840 won't connect to the internet
JAF47
I purchased an RBK840 to improve WiFi coverage. I used the phone app for setup. Everything went well until I connected it to my modem, a Netgear CM700. The app indicated that the cable was connected, but never connected to the internet. The modem works fine connected directly to a laptop computer or through the old router. Is there a setting I should change, either on the router or modem?
Message 1 of 6
Accepted Solutions
Guru
Re: RBK840 won't connect to the internet
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Message 6 of 6
All Replies
Guru
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Message 2 of 6
JAF47
I can now connect to the internet, but when I attempt to load a web page, I get a "Connection isn't private warning (Windows WiFi) or "Can't establish secure connection" error (Mac connected to router by ethernet cable).
Message 3 of 6
JAF47
Update:
I logged on to orbilogin.com on my desktop PC to look into updating the firmware as suggested in the user's manual. When I did, I was returned to the set-up process. I did get a notice of an IP address conflict, and that it had been changed to 10.0.0.1. Then a screen appeared to allow updating the firmware, which I did. After that the system is working great with a noticeable increase in speed over the old router.
Message 5 of 6
Guru
Enjoy. 📡
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 854 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
