- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK852 WiFi Speeds
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBK852 WiFi Speeds
Just setup our new RBK852. We did have an Orbi RBR50. We have 1gb service through Spectrum and it does reach close to 1gb hardwired.
On the RBR50 with iPhone 11 Pro speeds were usually around 328 down and 57 up. On my iPad 11 Pro speeds were 410 and 44 up.
On the RBK852, the iPhone 11 Pro speeds are around 700 up and 57 up. And on the iPad 11 Pro the speeds are 600 up and 51 down.
I know the iPhone 11 Pro has the chipset to take advantage of wifi 6, so should I be getting close to 1gb speeds on it via wifi and if so, is there anything I have to do in the settings to get that?
Has anyone done any comparison to the Linksys Velop Wifi 6 mesh system? I might get that too and see if it is much different, although always have good success with the Orbi's. Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK852 WiFi Speeds
Use WiFi Sweet Spots on your iPhone to see what the connection rate is between the iphone and RBR...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wi-Fi Sweetspots shows connection from 672 to 693. Is that what you need? Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Anyone else have anything to add about my speeds? Appreciat the help. 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your speeds sound perfectly normal to me. Getting a full 1 Gps connection over WiFi 6 would require you to be probably within a foot or two of the router and having all other conditions be perfect in the room. The full advertised speeds are rarely, if ever, achieveable in the real world.
Out of curiosity, how close are you to the router when you test your speeds?
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
