- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK852 compatibilty with RBS50Y
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
It does seem Netgear has not yet released an Orbi Outdoor Wifi 6 extender ...
So, could the current Orbi RBS50Y be fully compatible with the RBK852 ?
Thanks in advance for your comments
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
For now, yes.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK852 compatibilty with RBS50Y
It's not currently supported. NG was said to make the RBS50 and RBS50Y compatible at some point. No information on this as of yet on when or of this will happen.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
Thanks a lot for your insight.
Basically, if my understanding is correct ... should I desperately need to buy the RBS50Y Outside unit, as a consequence, it also means that I have to change my router and purchase the RBR50 ...
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
For now, yes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK852 compatibility with RBS50Y
Hi,
Again ... Many Many Thanks for your precious advice ...!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good Luck.
