Orbi WiFi 7 RBE973
Reply
RBK852 firmware 3.2.16.6 question
dmw_2
Guide
I see that the release notes say this version now - Supports enabling or disabling the wireless 11AX mode on 2G or 5G separately - but I would appreciate some clarification.  Being unfamiliar with exactly how or if 11AX differs from the various earlier wifi versions of Orbi I have used (presently on RBR50 and RBS50 x2) does this mean you can now switch off the 5G signal completely if you need to?  For instance while trying to connect a 2G only device?
Message 1 of 4
Accepted Solutions
Guru
Re: RBK852 firmware 3.2.16.6 question
Oribi WiFi 5 is AC mode supporting, this is just a wifi mode that supports higher speed than WiFi 4 or N mode. AX is wifi 6 thats just a mode that supports higher speeds than AC does. The support of disabling of AX mode is only disabling of the mode on either radio, not the radio themselves.
Message 2 of 4
All Replies
Guru
Message 2 of 4
dmw_2
Guide
Thank you for that explanation which I understand, David
Message 3 of 4
Guru
Smiley Wink
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1238 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
