- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK853-Are both 5Ghz radios client-usable IF a purely wired (ethernet) backhaul is used?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can someone confirm what happens with the 2nd 5Ghz radio when you setup Orbi in a purely wired/ethernet backhaul?
Does the previously backhaul-dedicated 2nd 5Ghz become available for client usage (load balancing the 2) or is it 'shut off' (which seems to be a waste?) if wired backhaul is utilized?
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK853-Are both 5Ghz radios client-usable IF a purely wired (ethernet) backhaul is used?
The 2nd 5Ghz radio is NOT user configurable when ethernet connected. Same goes for Orbi AC.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
