x19
Feb 09, 2023Guide
RBK963 make over
A bit of make over to the standard Orbi...
Liquid vinyl spray and USB blue Led strip always on.
Really would like the Led to be on all Orbis as standard.....
Interesting look. Hopefully it doesn't void the warranty if you have any issues
- x19Guide
It is a beta unit... Also the led strip can easily be removed and the vinyl paint is the same I used on the alloy wheels of the car which can be peeled off. Not 100% sure but on plastic should be the same
Good to hear its a beta unit. Not much support on those except for the beta crew.
Nice little upgrade to make it stand out a bit more. Funny cause usually you see people asking for less light on them 🙂
