Orbi WiFi 7 RBE973
Reply
RBR 750 Problem
cjlutz
RBR 750 Problem
My Orbi RBR 750 Router is not connecting to my ISP modem. I've tried all of the troubleshooting methods without success. On the Orbi Iphone app I get an "orbi not found" message. I've tried a factory reset and reboot on the router and it has a solid white light. I connected to my ISP modem and the connection to the Orbi router fails the connection test. I see the ORBI93 wifi network on iphone and laptop but clearly an issue connecting that I can't fix.
Any suggestions appreciated!
Message 1 of 10
Yahey
Re: RBR 750 Problem
Hello Community,
I have the exact same issue.
Installed firmware = NETGEAR Orbi 2.12.6.1824
Smartphone used = Google Pixel 5
There's no other ORBI network around.
I unactivated mobile data on the smartphone to be sure to used ONLY Orbi WiFi LAN connection.
Connection to web admin interface works just fine.
Any idea ? Thanks.
Kind regards,
Message 2 of 10
Guru
Re: RBR 750 Problem
@cjlutz What modem/gateway is the orbi connected to?
Current setup: CM2000-> RBE973S-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/100mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 3 of 10
Guru
Re: RBR 750 Problem
Please make a new post in regards to what your having problems with.
Thank you.
@Yahey wrote:
Hello Community,
Any idea ? Thanks.
Kind regards,
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBE971 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 4 of 10
Yahey
Re: RBR 750 Problem
Hello Cjlutz,
Thanks for the prompt feedback.
My ISP box (fiber). Orange Box.
The box has its own IP range.
The ORBI has another one.
Message 5 of 10
Yahey
Re: RBR 750 Problem
OK
Message 6 of 10
Guru
Re: RBR 750 Problem
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
@Yahey wrote:
Hello Cjlutz,
Message 7 of 10
cjlutz
Re: RBR 750 Problem
It's a Verizon moden
Message 8 of 10
cjlutz
Re: RBR 750 Problem
Thanks for feedback. Not sure I have the confidence to do that without screwing it up. The wifi through the modem works...just don't have the same range. Why do you think it suddenly stopped working?
Message 9 of 10
Guru
Re: RBR 750 Problem
Contact your ISP to have them help you with the modem.
If both modem and orbi wifi are running, noise and interferences between each other can cause problems. Why it's recommended to run only 1 wifi system in a household.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 994 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
