Orbi WiFi 7 RBE973
Reply
RBR350 Remote Management Web
niroooo
Is remote management via a browser possible with the RBR350 router?
I'm running the latest firmware v4.4.0.10 and cannot see any options to enable remote management under the Advanced settings. I do have a static internet ip address so this would be really handy as remote access via the app is more limited.
Message 1 of 2
CrimpOn
Guru
Re: RBR350 Remote Management Web
As far as I know, that web based Remote Management feature has been removed from all Orbi models.
The only way I know of to enable access to the web administration is by enabling OpenVPN on the Orbi router and using the VPN tunnel to reach the Orbi LAN, where the Orbi router is the gateway (usually, 192.168.1.1)
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 604 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
