Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR750 + 4 satellites as AP’s
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-08-17
06:34 AM
2023-08-17
06:34 AM
I am confused as to how Access Points are supposed to behave where connections are concerned. If I setup my RBR750 and satellites to use as access points, how would a mobile phone connected to WiFi behave? Would it connect to whatever AP is closest as I move through house or does it stay connected to one satellite all the time?
It seems to stay connected to one specific satellite which is not always the most optimal connection.
I seem to have multiple devices that connected to a satellite that is not optimal….yet that’s the one they chose. Is there a way to get them to connect to the strongest signal?
Message 1 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-08-17
06:45 AM
2023-08-17
06:45 AM
Re: RBR750 + 4 satellites as AP’s
It's up to wifi devices to pick and choose where they connect too. Orbi just provides the platform is all.
Disable the wifi radio on the wifi device for 5 seconds them move closer to the nearest RBS or RBR, then re-enabled the wifi radio on the wifi device. It should connect to to the closer signal.
Message 2 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-08-17
06:55 AM
2023-08-17
06:55 AM
Thank you, yes I have tried that. It sort of works but then when I leave the house and come back it starts all over again. But I understand it is probably a limitation to the device more so than the satellite or network itself
Message 3 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-08-18
07:10 AM
2023-08-18
07:10 AM
Most likely.
What is the distance between the router and 📡 satellite(s)?
Message 4 of 4
Announcements
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
