Orbi WiFi 7 RBE973
Reply
RBR750 Never worked correctly, opened tickets, now not supported - buh bye
gmcateer
Follower
Lack of support is amazing. They never could resolve my connection issues, this network has limped along and now our support is expired. Only option is to pay for more? Will never buy Netgear again.
Message 1 of 2
Guru
Re: RBR750 Never worked correctly, opened tickets, now not supported - buh bye
Lets see if we can help you here...
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is Armor, Smart Parental Controsl, or Traffic Meter enabled?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 245 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
