- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR750 No connection/solid magenta
- Mark as New
- Bookmark
- Subscribe
- Permalink
Rebooted multiple times to no avail.
Hard line connection to modem from laptop is fine.
Satellites show they are fine.
Firmware update fails from app every time I attempt. Currently running 4.6.5.14_2.0.54.
Any ideas or is it bricked? System is only 13 months old.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Found a newer CAT5 in a stash of cables & used it after a factory reset of router & all satellites.
Factory reset & adding satellites back in one by one by using the app AND pressing sync on the router PRIOR to sync on the satellite seems to have solved the issue.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR750 No connection/solid magenta
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Motorola MB8611
Connected to Xfinity
Home is 3000sf
~30ft from router to each satellite
Wi-Fi neighbors on each side, weak signals
All devices have been power cycled per these instructions multiple times today.
No connection to internet even when wired directly to router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the CAT# LAN cable between the RBR and ISP modem? CAT6 is recommended.
Pink means the RBR has lost connection with the ISP modem or ISP Modem isn't giving good ethernet connection or services.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
- Mark as New
- Bookmark
- Subscribe
- Permalink
Xfinity says signal to modem is strong.
Speedtest directly from modem is:
578 down / 40 up
- Mark as New
- Bookmark
- Subscribe
- Permalink
CAT5 only supports connection speeds up to 100Mpbs. I recommend you get a CAT6 STP or UTP lan cable in between the modem and router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know if it continues after getting a CAT6 in place.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
