- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR750 Problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have RBR750 w/ 2 satellites that had worked flawlessly until recently. I think it began with the latest firmware update,
I’ve tried resetting the modem and router several times. I tried rebooting the router from the app. I was on the phone with my ISP last night, I again reset the modem with them; they couldn’t identify a problem.
HELP! Has anyone had this problem and found a solution? I need a good wifi to work from home.
Thank you
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@msfurry wrote:
I'm sorry. The problem is I can't reach the Internet.
Do you have a computer or laptop that can be connected directly to the ISP modem. That will confirm that the ISP is correct about the modem working correctly.
When the Orbi router is powered on, the ring light at the top should go through some color patterns for about 2-3 minutes and end with glowing either blue or magenta for three minutes. What happens when you turn it off and back on? (I know it seems like an eternity.)
Do you use the Orbi 'app' or the Orbi web interface to administer the system?
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR750 Problem
It would help if you describe the problem. Does the entire system fail to provide WiFi? Does it disconnect from the internet? Do some web sites not load? "problem" doesn't provide much information.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR750 Problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR750 Problem
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
Turn off and unplug modem.
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR750 Problem
Not really. I left it alone for a while then followed CrimpOn suggestions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR750 Problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
