- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR750 admin page won't load -- responds to ping but not HTTP GET
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR750 admin page won't load -- responds to ping but not HTTP GET
It might be worth taking a few minutes to attempt setting up the Orbi without any connection to the WAN port.
(yes, no cable to the ISP device). An Orbi will function perfectly well with no internet connection. (it cannot reach the internet, but the WiFi and LAN operation will be just fine.)
There is a chance that the Orbi is not actually at 192.168.1.1 "something" may be there, but perhaps not the Orbi. For example, if the Orbi is connected to an ISP router that takes 192.168.1.1 for itself, the Orbi will switch to 10.0.0.1.
With a computer connected to an Orbi LAN port, what is the gateway address that the computer gets via DHCP?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the suggestion. I've tried without anything connected to the WAN port but that doesn't seem to matter (direct ethernet connection from laptop to router with no other connections on the laptop or the router). The router always assigns connected devices an IPv4 from 192.168.1.0/24 with gateway 192.168.1.1 (e.g. 192.168.1.2 or 192.168.1.3). Pings from the laptop to 192.168.1.1 start flowing a minute or two after the router boots up, and stop immediately if the router is unplugged. Can't ping 10.0.0.1 and web page does not load. So I think the orbi is indeed using 192.168.1.1.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for humoring me. I agree with your conclusion. The Orbi router is at 192.168.1.1.
I can think of no explanation for why two RBR750 routers should both behave this way. There are a lot of complaints about the 750 product, but this situation is totally new. Before it goes back, I can think of one more experiment: Unless the ISP requires a user name and password to get access, Orbi routers are like typical ISP products. They will function without any setup at all.
i.e. They broadcast the WiFi SSID listed on the product label (bottom) and accept the password on the label. WiFi devices and wired devices get internet access and "off we go."
Do devices connected to this Orbi have internet?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Interestingly, when the orbi is connected to the internet (over WAN port), devices attached to the LAN ports (or orbi WiFi) can ping out to public IP addresses, but nothing else works. Web pages won't load. Curl commands fail. Maybe it's dropping or not handling a certain type of traffic correctly, like TCP? In any case, the router still isn't usable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is there a way to determine the firmware version without access to the admin page or orbi app? Maybe through a console port or something? Otherwise I don't think it's possible to determine the firmware version.
The issue is not related to my ISP modem, since it was the same behavior before connecting the orbi to the ISP modem. But for reference it's an Arris BGW210.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
You may need to disconnet the RBR fron the ISP Modem and factory reset the RBR and set it up from scratch with out it being connected to the ISP Modem first. You should be able to access 192.168.1.1 on the RBR using a web browser and wired PC connected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your last sentence "You should be able to access 192.168.1.1 on the RBR using a web browser and wired PC connected." captures the problem -- I am unable to access 192.168.1.1 on the RBR even after a factory reset and wired PC connection.
- Mark as New
- Bookmark
- Subscribe
- Permalink
And you reset the RBR by pressing the reset button for 15 seconds then release and with the RBR not connected to the ISP modem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I've reset it by holding down reset for 10-15 seconds and confirming the light starts flashing without a connection to the ISP router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
How long are you waiting after the reset before attempting to connect to 192.168.1.1? I presume if your waiting for 1 minute or longer and you can't get to the RBRs web page at all, i'd make contact with NG support and see what your options are. Ask about RMA options.
