Orbi WiFi 7 RBE973
Reply
RBR750 and RBS750 not seeing each other with wired backhaul
dbrb2
Apprentice
I have an RBR750 set up in AP mode
I also have an RBS750
Both are running V4.6.14.3
Both units are connected to a switch via their LAN ports (I am not using the RBR as a router)
Both units are reachable, and both are providing wifi access succesfully to various devices.
However, the RBR750 shows "0 satellites connected" and likewise the RBS750 shows that it has no connection to the router
From what I had read, I though these two units should be able to see each other using a wired backhaul...?
Message 1 of 20
Guru
Re: RBR750 and RBS750 not seeing each other with wired backhaul
What is the Mfr and model# of the host router the NG router is connected too?
How is the RBR connected to the host router? WAN port?
Whats the brand and model# of the LAN switch being used?
What CAT# LAN cable is being used? CAT6 is recommended.
Try the RBS directly connected to the back of the RBR with out the switch?
Message 2 of 20
dbrb2
Apprentice
RBR750
Firmware Version V4.6.14.3_2.3.12
GUI Language Version V3.0.1.54_2.1.30.3
RBR is connected to the main gigE switch using a cat6 cable
RBR is set up in AP mode
The internet router is also connected to this switch
The WAN port on the RBR is not used
It's an unmanaged 8 port gigE switch from TPLink - TL-SG108S
How do the devices discover each other?
CAT6
Unfortunately that would be a problem with the available cabling. I might be able to work something out temporarily though. However, at that point they would be so close that I presumably wouldn't know if the backhaul was wired or wireless...?
Both devices are visible on the network - and both are providing wifi access to devices - but if they are not seeing each other, that presumably means both are acting as standalone access points....which may or may not have any real-world effect in terms of device handover etc...?
Message 3 of 20
Guru
RBR750
What is the other routers brand name and model# that the RBR750 is connected too?
The WAN port on the RBR is not used <The WAN port on the RBR while in AP mode HAS to be used for proper operation of the RBR AND RBS.
CAT6
Something to try as a quick test to see if the RBS sync over ethernet to the back of the RBR and they show properly when ethernet connected on the RBRs web page. Wired status should appear for each RBS after they successfully sync over ethernet.
Message 4 of 20
dbrb2
Apprentice
Ah sorry I made a mistake:
I am (and have always) been using the RBR WAN port in AP mode.
In AP mode then, the WAN port does not merely become another LAN port?
I have connected the RBS to one of the RBR LAN ports, and the RBR now shows "12 sat connected, connection type wired"
Likewise, the App shows the RBS connected
The RBS web interface itself seems a little confused, showing the router greyed out - but maybe that is because it has no graphic for a wired connection...
The fact this works might suggest that to use the wireless backhaul you have to use the RBR LAN ports - but to operate in AP mode you have to use the WAN port....so the RBR would need two cables run to it...? If so, I might go back to the old setup 🙂
Thanks!
Message 5 of 20
CrimpOn
Guru
Would it be correct to conclude that physical wiring layout is responsible for the way devices are connected?
i.e. two devices are located at a central wiring hub:
  • Internet Service Provider (ISP) router, and
  • 8-port gigabit switch
The Orbi router, Orbi satellite, and perhaps other user devices are located in different locations using Ethernet cables which connect to that wiring hub.
There is only a single Ethernet cable from the hub to the location of the Orbi router.
Locating the Orbi router at the hub is undesirable for one reason or another.
The traditional method of using the Orbi in Access Point (AP) mode would be:
ISP Router -> Orbi Router WAN (in AP mode) -> LAN port to gigabit switch
Everything else connected to the gigabit switch.
Message 6 of 20
Guru
Ok so if you have one RBS directly connected to the back of the RBR, this may point to the LAN switch your using? Or a bad cable in beteen the RBR, switch and from switch to RBS at it's remote location. Something is blocking proper data flow between the RBR and RBS.
NG GS-105/108v4 and GS308v3, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems.
Thanks!
Message 7 of 20
dbrb2
Apprentice
This is the setup I was trying to use - which resulted in the two Orbi units being individually reachable, but not seeing each other:
This, below, is the only setup so far where the two devices successfully see one another:
I've tested out the cables, so am confident there is no problem there. But perhaps backhaul only works when using the LAN port on the RBR....?
I'm going to try NOT using the WAN port on the RBR at all, and see what effect that has
Message 8 of 20
dbrb2
Apprentice
Ah OK....
THAT seems to be working - though I will keep an eye on it....
It looks like when in AP mode you can use the WAN port as a LAN port for some things - but NOT for backhaul
That seems to correspond to what this gent found:
https://community.netgear.com/t5/Orbi-Wi-Fi-5-AC-and-Orbi-with/Orbi-RBR750-Wired-Backhaul/m-p/217813...
Though the RBS still shows no connection to the router:
Both the App and the RBR do show a connection to the satellite....so fingers crossed all is OK.
Are you aware of any potential pitfalls to not using the WAN port? Given the RBR is not being used as a router, not using the WAN port does make some sense
Cheers!
Message 9 of 20
dbrb2
Apprentice
Yes @CrimpOn  - see diagram in reply above
The central hub is where the router and switch have to be - but is also between two very thick structural walls, so is a poor place for the Orbi. I aso needed some features from the router firewall not available when using the Orbi in that mode
This is the layout that (touch wood) seems to be working OK - with the RBR WAN port unused, still in AP mode:
Message 10 of 20
dbrb2
Apprentice
The only problem I have found so far with this setup (not using the WAN port on the RBR) is minor:
The f/w update page shows "no internet" - suggesting it is only checking the WAN port for connection to the world
So far as I can tell, everything else is working OK though
Message 11 of 20
Guru
There are other items of Orbi that depend on use of the WAN port, when in router or AP mode.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Message 12 of 20
dbrb2
Apprentice
Ah thanks - I will mark it as resolved soon.
Can you think of any of the other functions that need the WAN port? I just want to check it isn't anything that might impact on its ability to work as a mesh network. So far, it _seems_ to be working OK!
Cheers,
Ben
Message 13 of 20
Guru
Front LED status operation and FW update checking are others. NG intended the WAN port to be used always. The Orbi systems and some Nighthawk routers are same way. Regardless of AP mode, WAN port needs to be connected.
Message 14 of 20
dbrb2
Apprentice
Ah Ok
Having said that, the unit does seem to work with the WAN port not in use - so if I am happy to rely on manual firmware checks and some cosmetic LED issues I'll be OK at a functional level?
Since the wired backhaul doesn't seem to work when using the WAN port, I think I'll have to stick with the current setup
The ideal solution I guess would be for the firmware to be fixed so that either backhaul worked with the WAN port in AP mode, or even better that the unit didn't need the WAN port when not in router mode (since if its not routing, WAN and LAN have no meaning) - but or an older product I guess that may not happen
Message 15 of 20
Guru
IF thats how you want to run it. Your choice. Intended design is to use the WAN port. The wired backhaul works when using the intended WAN port for the RBR connected to the main host router and LAN ports ethernet connected to the RBS.
Only issues that can be seen that can inhibit good operation is bad cabling or a bad switch in between that can block good data flow in between the RBR and RBS. No FW fixes are needed when used in this intended configuration.
My Orbi AX systems work well for me in this configuration with using the WAN port. If yours isn't working then you'll need to find out where the problem is.
Message 16 of 20
dbrb2
Apprentice
Understood
Unfortunately having to use the WAN port for the connection to the main switch, but one of the the LAN ports for the backhaul to other RBS units, would in my case mean running two cables to the RBR - since in my case the main switch and router are by necessity remote from the RBR location.
Running just one cable to each unit from the main switch to the units LAN port, so far as I can see, works almost perfectly. It just looks like there are some oddities with the RBR meaning even when in what is nominally non-routing (AP) mode, some functionality doesn't quite work - presumably because it was originally designed to be a router, and when using it as AP it is a bit rough around the edges.
Message 17 of 20
Guru
Ethernet connected RBS should be connected as such so it works correctly, router or AP mode:
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy... 📡
This is tried and true that works.
Message 18 of 20
dbrb2
Apprentice
Interesting!
The image below - taken from the page you linked to:
Is in fact my setup - RBR and RBS LAN ports back to a central switch, but the yellow "WAN" port on the RBR is not connected at all
Message 19 of 20
Guru
Correct, as the RBRs WAN port is/should be connected to the ISP modem or upstream router here when in router or AP mode.
Message 20 of 20
Top Contributors
Discussion stats
  • 19 replies
  • 1441 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
