Orbi WiFi 7 RBE973
Reply
RBR750 port forwarding stopped working
jixxer
Re: RBR750 port forwarding stopped working
@CrimpOn
Yes each device needs the same config file or QR to setup the first time but doesn't need to be updated unless something changes (IP)
I'm guessing you're seeing it on the Orbi because its being hosted part of the Orbi FW but if you connect directly to WG then it wouldn't show since traffic is routed through there as you mentioned. I have never hosted on main router so wouldn't know for sure and not sure if its suppose say its connected remotely even if VPN is working correctly.
I would have someone out of state or country connect to your WG server and see if your public IP shows up on their end, then you know its working as it should.
Message 26 of 26
Top Contributors
Discussion stats
  • 25 replies
  • 5261 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
