Orbi WiFi 7 RBE973
Reply
RBR750 satellite (RBS350) does not show up in attached devices
JackStir
Hello, I just purchased the Orbi RBK652S system 7/6/24. I have owned ASUS routers for the past 10 years so I am still trying to learn this system. I was using the Orbi app the next day (7/7) and noticed I had a notification. The notification was for a firmware update for the satellite (RBS350). I performed the update and then all my trouble started. The satellite would not connect to my system. Tried resetting several times but no luck. It looked like it was connected by lights on the front but I had no clue because it would not show up connected via Orbi app and Orbilogin on my PC. I removed the satellite and tried to resync it through the app. It stated that it could not find the satellite. I tried this several times but no luck. I called technical support this morning but the person I talked to seemed to want to get off the phone. We did a hard reset (held reset button for 90 seconds) and now the satellite is connected but I mentioned it was not showing up in the Orbilogin. I was told it was connected and the case would be kept under observation and kept open for 4 hours. I am plugged into it with an ethernet cable as we speak so I knowit is connected but my issue is that it still will not show up on the app or orbilogin on PC. Also on the Advanced tab/ Firmware Update/ Manual Update in the orbilogin on PC, the satellite does not show up. How should I proceed?
Any help would be greatly appreciated. Thank you.
Message 1 of 9
Accepted Solutions
All Replies
Guru
Re: RBR750 satellite (RBS350) does not show up in attached devices
What FW version is on the RBS and on the RBR750?
Be sure that you don't update the RBR750 to any v7 version of FW as that is NOT compatible with RBS350.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/New-RBR760-RBS760-Firmware-Version-...
If the RBR750 was update to v7, you'll need to downgrade the RBR back to v6 version listed in the link posted.
Message 2 of 9
JackStir
I am on firmware version V7.2.6.31_5.0.24. I do not know what version the RBS is on. It is not listed as an attached device.
Message 3 of 9
Guru
You'll need to downgrade the RBR back to v4 FW.
Message 4 of 9
JackStir
Do I do that through the manual Update tab in the Advanced tab?
Message 5 of 9
JackStir
Thank you very much! That fixed my issue. I will mark your prior comment as the solution.
Just wanted to note that I had to manually update (downgrade) the router 1st and the satellite 2nd even though it was recommended to update satellite 1st and router 2nd. The downgrade worked perfectly even though it was not performed in the recommended of order. Thanks again!
Message 7 of 9
Guru
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Message 8 of 9
JackStir
I saved a back up file as soon as I saw it was working. Thanks again.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1243 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
