Orbi WiFi 7 RBE973
Reply
RBR750 slow
Mikems
RBR750 slow
I bought an RBR750 a few months ago and checked my speed from ORBI speed test.  It shows 575 which is good since I have around 500.  Then I ran several tests from the internet and they show under 200.  Why is this so slow?  What can I do?  I purchased from Costco so I could return it?
Message 1 of 10
CrimpOn
Guru
Re: RBR750 slow
Please explain how you ran tests "from the internet".  What device? What test?
In general, devices connected to the router over WiFi cannot achieve the same rate of speed as devices connected with Ethernet cable.
Message 2 of 10
Mikems
Re: RBR750 slow
I did run this with my phone connected to the wifi (orbi).
Message 3 of 10
Mikems
Re: RBR750 slow
I used several different internet speeds tests and all tested about the same.  I realize the wifi is going to be a little slow but it is more than 1/2 of the speed I am suppose to get.
Message 4 of 10
Guru
Re: RBR750 slow
What devices do you have connected?
Be sure to speed test with a wired PC connected to the RBR.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Message 5 of 10
Mikey94025
Hero
Re: RBR750 slow
Wi-fi speeds are very limited depending upon your device and wireless band.  The speeds will virtually always be a bit less than what your Orbi speed test is reporting (wired speeds, not wireless).
This site shows realistic top speeds for various wireless devices: https://support.google.com/fiber/answer/6250056#zippy=%2Cmobile-devices-wi-fi%2Ccomputers-wi-fi%2Cco....  Don't worry if your wireless device speed test is near these max numbers.
Mobile devices (Wi-Fi)
Release date
802.11 version
Maximum possible speed
2020–present
802.11ax (Wi-Fi 6)
500 Mbps
2013–present
802.11ac
180 Mbps–390 Mbps
2011–2012
802.11n
90 Mbps
2007–2010
802.11n
32 Mbps–90 Mbps
2006 or earlier
802.11a/b/g
32 Mbps
Computers (Wi-Fi)
Release date
802.11 version
2020–present
802.11ax (Wi-Fi 6)
700 Mbps
2013–present
802.11ac
195 Mbps–585 Mbps
2011–2012
802.11n
180 Mbps–270 Mbps
2007–2010
802.11n
90 Mbps–180 Mbps
2006 or earlier
802.11a/b/g
32 Mbps
Message 6 of 10
Mikems
Re: RBR750 slow
Ok I am running this test on my galaxy fold 3 newest model. I have 575 MG registering from the modem using the orbi test under the orbi application. This is correct since I have 500mg from the provider. Then when I test again from my phone wirelessly I get under 200mg for a speed. Ok I understand there is a drop in mgs but 300 less? I have tried many internet speed tests all testing around the same.
Message 7 of 10
Guru
Re: RBR750 slow
What is the distance between the router and ‌‌ satellite(s)? 30 feet or more is recommended in between RBR and RBS‌‌ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌
Message 8 of 10
Mikems
Re: RBR750 slow
It is not the modem it tests at 575mg. I have 500mg service. It is spectrum my service provider. I downloaded the latest firmware.
Message 9 of 10
Guru
Re: RBR750 slow
What specific Firmware version is currently loaded?
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 1185 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
