- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- Next »
RBR750 unable to assign IP addresses after reboot
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR750 unable to assign IP addresses after reboot
Yep. Never can tell what those spurious electrons will do! 😂
I will try enabling SIP ALG and see if there is any change. I already limit my DHCP pool to only 50 devices. I use XXX.XXX.X.1 thru .50. Never had an issue with DHCP assignments on either my original ORBI 50 or the current ORBI 750 using that scheme.
I also use IP reservations for every one of my 42 devices. It is my OCD showing through but I find it way easier to troubleshoot device connection issues if I do this. It also allows me to immediately notice if a "new" device has connected to my WiFi. (BTW, I do not use static IP addresses on the device side. It is very difficult/not possible on some devices to set this up.) While I cannot prove it, I believe folks having issues with DHCP assignments are overdriving their systems with too many devices. With 42 devices, I'm probably bumping up against the limit sometimes. When my current 750 gives up, I'll upgrade to the larger capacity 800 or 900 series.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds like your system IS now working well and your not seeing any IP address assignment issues. Be sure to save off a new back up configuration to file for safe keeping. Saves time if a reset is needed.
Ya seeing problems in other NG router models and sometimes here on Orbi, wondering if there is a problem with using the wider IP address pool size. Been thinking there maybe some underlying issues with this kind of default configuration. Since I've been using the smaller pool size for years, I've not seen these issues to date or any oddities in this area. I may bring this up with NG and see what could be done. We know there are some other underlying issues at hand that need to be fixed. These could be causing extra problems as well.
I use this as a kind of a general rule for STATIC assigned devices, items that don't need much or any router management, devices that need some access but can be set and left alone and not accessed but occasionally, and devices that do have management pages that support input of static IP addresses. Devices like Printers, NAS, Cameras are some devices that don't need much and generally can be configured for Static IPs. I have 3 printers, 2 NAS and 3 cameras, all set for statics. Anytime I change out the home network router, I just make sure the incoming router has same network configuration and onces it's online, the static devices are automatically connected at there known IPs. No need for worry about them.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you using default DHCP IP address pool range?
What happens if you change that to .100 to .200 next time you use Orbi?
@raven_au wrote:
I'm pretty sure that I've seen this on all current firmware, including 4.6.9.11.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you seen this problem continue with the new FW?
I use .80 to .249 for the DHCP range.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:Have you seen this problem continue with the new FW?
@raven_au wrote:
@FURRYe38 wrote:Are you using default DHCP IP address pool range?
@raven_au wrote:I'm pretty sure that I've seen this on all current firmware, including 4.6.9.11.
I'm not using the Orbi right now.
I may put them back into use and check if v4.6.14.3 helps.
That version wasn't showing on the Netgear site when I posted the above.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Kewl, let us know the results when you can.
Thank you for your time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I updated to V4.6.14.3 and it still doesn't work.
I had to restart my router today to move some things around and now nothing is connecting on wifi again.
I enabled SIP ALG and have set my range from 2 to 249.
I can't limit to 50 pool size for devices because I live in a multi family and we have about 125+ devices, not counting visitors.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I took the time and set all my IOT devices to the guest network. So far no more issues in rebooting.
- « Previous
- Next »
