Orbi WiFi 7 RBE973
Reply
RBR750 - unstable, satellites keep disconnecting
Guru
Re: RBR750 - unstable, satellites keep disconnecting
Ok, let us know how that goes. 🤔
Message 26 of 30
weirdbeardmt
Will do. One thing that seems to occur is that when the RBS disconnect, then the other RBS seem to interfere/prevent the reconnection. These past few times, the RBR has still been accessible via wifi.
I don't know if this is happening or why it might be happening if so. But in theory with only one RBS running then if it does disconnect then it should be able to reconnect (since there are no others powered on.)
Message 27 of 30
Guru
Let see how it goes. May at some point, try each one of the other RBS, one at a time, connected to the RBR to see if those can keep connected to the RBR.
Message 28 of 30
weirdbeardmt
It's a good shout... because at this point I am honestly starting to wonder if there's some hardware failure going on
Message 29 of 30
Guru
One way to may help find that out. 😏
Message 30 of 30
Top Contributors
Discussion stats
  • 29 replies
  • 2244 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
