Orbi WiFi 7 RBE973
Reply
RBR750
Rapidserv
RBR750
Can I connect to my surveilance console system? I need ethernet and not not want to drill hole in the walls to make this connection.
Message 1 of 4
CrimpOn
Guru
Re: RBR750
This question requires more detail.  What is this surveillance console system?
Is the problem that this equipment has an Ethernet jack but does not support WiFi?
Message 2 of 4
Rapidserv
Re: RBR750
Security system is Lorex. It is not WiFi compatible. It is hard wired in. I would like to connect to the Orbi which would talk to the Orbi router which would be connected to the WiFi Router. (bridge)
Message 3 of 4
CrimpOn
Guru
Re: RBR750
If I understand correctly
  • The Lorex console is in one location
  • There are no Orbi units in that location
  • The goal is to access the Lorex console from other locations
One solution is to install some product next to the Lorex console that will:
  • Provide an Ethernet jack to connect to the Lorex console, and
  • Connect to the Orbi system over WiFi.
Many models of "WiFi Extender" can do this. For example, the Netgear EX3700 https://www.downloads.netgear.com/files/GDC/datasheet/en/EX3700.pdf
The EX3700 is available on Amazon for under $30US.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 558 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
