Orbi WiFi 7 RBE973
Reply
RBR850, RBS850, 2x RBS350 "Out of sync" & default "password"!!!
alternet
Tutor
Hi all,
I got RBR850 with RBS850 ....for a while everything worked well. After a while I had to add some more coverage to my system and got 2 additional satellites RBS350 (following compatibility list: https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible)
All satellites are connected via cable directly with the router and after couple minutes once restarted getting out of sync:
Firmware recently updated to the following versions:
RBR850: V4.6.14.3_2.3.12
RBS850: V4.6.14.3
RBS350: V4.4.1.29
RBS350: V4.4.1.29
Even though the status is "Out of sync" devices are connecting to the satellites - but still it is very annoying! Is there any solution (already tried restarts, reconnection, factory rests....)?
The other problem is that satellites' password cannot be changed! RBS850 takes over the router's password, but the RBS350s work only with the default "password"!!!! This is something not accepted in 2023!!! Please make a solution for this since the satellites' interface does not offer an option to change the password!
KR
mc
Message 1 of 28
Guru
Re: RBR850, RBS850, 2x RBS350 "Out of sync" & default "password"!!!
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
What CAT# LAN cable are you using between the RBR and RBS? CAT6 is recommended.
Are the RBS directly connected to the back of the RBR or is there a LAN switch or patch panel in between?
IF you turn OFF the RBS850, does the RBS350 sync correctly to the RBR850?
Message 2 of 28
CrimpOn
Guru
Do I read this correctly that the RBS350 satellite web sites accept a web connection using the credentials "admin" and "password"?
(Not that the WiFi credentials on the satellites are not the same as the router and RBS850 satellite.)
This is almost certainly a result of that "out of sync" condition.  The reason there is no provision on the satellite web page to change the web password is that the router is supposed to automatically set the password on all satellites.
Could you try an experiment by disconnecting the Ethernet connection for a satellite and see if the situation changes?  Orbi device status pages take a while to update.  Depending on how far the RBS350 is from the router, it may be necessary to temporarily relocate the satellite closer to the router (even in the same room) for the test.
Message 3 of 28
alternet
Tutor
The house is about 4800sq ft (450m2)
Each device is at least 30 ft (10m) away from each other. The router and one RBS350 are on the same level, about 40ft away from each other and there are very thick walls between them. The second RBS350 is positioned a floor above in the opposite corner corner of the house, and the RBS850 is placed at the attic also at the opposite corner (the distances are still above 30 ft to each other and always tick walls between them).
Structural LAN is 6A... cables connecting satellites CAT6.
YES - the RBR850 is directly connected to the modem via the yellow port and other ports are linked to the satellites via patch panels (3x) and one goes to the main switch.
YES. After restarts everything is syncing correctly for a while and after that it is out of sync. This morning all three RBS were Out of Sync. Now all 3 are in status "Good" - totally do not understand it!
YES. Factory reset performed twice since FW update (also tried to use RBR as an AP, but my modem is not easy to maintain).
Message 4 of 28
alternet
Tutor
YES!!! Exactly!!!
The credentials are totally different!!!
Shortly after reboot it stays in sync for a while. Today it is in sync for a couple hours now.
This was the only way to get connected the devices in the fist place. The distances between RBR and RBS are too big the get them connected wirelessly so I had to place them next to each other for the first sync and then once it was synced I could position them in there spots and connect them via LAN.
Message 5 of 28
Guru
Were the RBS first wirelessly synced to the RBR before connecting them via ethernet cable?
Did you first connect the RBS one at a time fully before turning on the next RBS to get it synced?
Possible bad connection on the LAN cable between the RBR and RBS could cause this.
Message 6 of 28
alternet
Tutor
Yes
YES. One by one.
CAT6 between RBR and patch panel, CAT6A structural LAN, CAT6 between the wall and RBS.... had some issues getting CAT7 or 8 😉
Message 7 of 28
Guru
Possible that the connections or connectors or wall jacks could have some bad connections causing problems.
I presume if the RBS wirelessly connect and sync fine with out seeing the out of sync message, then when you go to ethernet connect them, this maybe what's causing the out of sync problem. The RBS are not properly getting synced over ethernet.
Message 8 of 28
alternet
Tutor
Even standing next to each other being connected with 6A cable getting message Out of Sync after a while - the problem lays somewhere else and I have no an idea where 😞
Already started to regret buying it 😞
Message 9 of 28
Guru
So with the RBS350, and just the 850, does the RBS850 work after a while and not show a out of sync message? Wireless and wired?
Message 10 of 28
alternet
Tutor
all RBS are connected to RBR via cable (due to distance and tick walls).
Only RBS850 keeps in sync for longar then a day.
When I checked the status earlier today RBS350 were out of sync. Checking it now all are in sync
The more I see the less I understand!!!
Message 11 of 28
alternet
Tutor
Here we go again:
Why is it happening that way? The RBS350 are Out of Sync most of the time!!! It seems like they are not compatible with the RBR!!! Getting crazy.
Message 12 of 28
Guru
Ya seems like there is problem with the 350s connecting to the 8 series system. You might leave them off for now until NG can review this and see what's going on.
I'd open up a support ticket:
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/about/contact-us/
@KevinLiT @Straq
Message 13 of 28
Stra_q
Hello,
Can you try disconnecting ethernet cable and connect wirelessly.
Make sure Router is on first. Give it a reboot if you will like. Wait 3-4 minutes. Then bring up one Satellite(closest one). Wait 5 minutes. Then bring up next satellite(Wait 5 minutes). Will like to see if out of sync will take much longer to happen. If does, there is a possibility of a memory issue with 350.
Message 14 of 28
iyang
NETGEAR Expert
Hi @alternet ,
Can you try to click "Advanced" --> "Firmware upgrade" page, and click "check" button?
You may see a new FW version, and suggest to upgrade RBS350 new FW.
Thanks.
Message 15 of 28
alternet
Tutor
Tried from RBR:
...and from the RBS end it is not possible since only manual upgrade is possible:
Message 16 of 28
Guru
Try sending the RBS FW file to the RBS web page?
Message 17 of 28
alternet
Tutor
Yes. This was the only way to upgrade the FW.
Message 18 of 28
Guru
Wondering if there is a FW issue being with FW on the 8 series is at v4.6.x and the RBS350 series is at v4.4x and .4.x not working with the v.6.x FW?
@Stra_q @Straq @iyang @KevinLiT
Message 19 of 28
alternet
Tutor
No an idea where the problem is. Just please be also informed that the RBR does not recognize the RBS350 series properly (see the details):
Message 20 of 28
Guru
Ya maybe a Auto Update service issue or since the RBS350 isn't correctly synced, this would be a result for this area.
NG will need to look in to this.
Open a support ticket if you haven't already.
Message 21 of 28
alternet
Tutor
I wish it was possible. My support expired on 2021-03-01 and since that time support is not available for me 😞
But thanks anyway 🙂
Message 22 of 28
Guru
Hopefully one of the forum moderators can help out. Though this may take some time. Make contact with them and hopefully NG can get this fixed. I would not run the 350s until NG gets something going for you.
Message 23 of 28
Straq
NETGEAR Expert
Will try to test this out today/tomorrow.
Will update.
In the meantime, there is a possibility my teammate might contact you to debug.
Best,
Straq
Message 24 of 28
iyang
NETGEAR Expert
Hi @alternet ,
Can you try to download RBS350 FW v4.6.14.3 via https://www.netgear.com/support/product/rbk653#download ?
Thanks.
Message 25 of 28
Top Contributors
Discussion stats
  • 27 replies
  • 2337 views
  • 5 kudos
  • 6 in conversation
Announcements
Orbi 770 Series
