Orbi WiFi 7 RBE973
Reply
RBR850 port forwarding not working after recent fix
mmorain
Tutor
I've recently received the fix for being unable to access my Orbi management interface, and that seems to have resolved that issue (thanks @ChristineT !).
However, since that issue started, I haven't been able to access port-forwarded services through the router. Is there anything that needs to be done to resolve that?
Message 1 of 3
Accepted Solutions
mmorain
Tutor
Re: RBR850 port forwarding not working after recent fix
One more reboot seems to have resolved this issue. Thank you!
Message 2 of 3
All Replies
mmorain
Tutor
Message 2 of 3
Guru
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 473 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
