Orbi WiFi 7 RBE973
Reply
RBR850
gwoit
RBR850
I have to replace  my modem with a new unit. The modem is supplied by Windstream. How do I connect it to my orbi router. I assume all other connections will remain the same
Message 1 of 14
Guru
Re: RBR850
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
Be sure to check out the Orbi Quick Installation Guide online as well.
Contact the ISP for additional help and support information regarding there equipment.
Message 2 of 14
gwoit
Re: RBR850
thank you for the reply. I was also wondering if the orbi will recognize the new modem once powered up in the sequence you have provided
thank you again
Message 3 of 14
Guru
Re: RBR850
Message 4 of 14
gwoit
Re: RBR850
Im sorry but im not at the house right now. I will check that out. I do know its the same model that it is replacing
Message 5 of 14
Guru
Re: RBR850
Message 6 of 14
gwoit
Re: RBR850
It is a Kinetic WiFi 6 modem T3280
Message 7 of 14
Guru
Re: RBR850
Ok, Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-...
Message 8 of 14
gwoit
Re: RBR850
oh my thank you. Probably a little much for me. Ill just have to look for something a bit more simplified
thank you again
Message 9 of 14
Guru
Re: RBR850
The ISP should be able to help you since that modem is there's.
Good Luck.
Message 10 of 14
gwoit
Re: RBR850
thank you. They claim that they do not sell anything else so they told me to plug in the new modem to the orbi and follow the steps you told me. They claim that if nothing else is connected to the router portion of the modem and only using the orbi that all should be ok
thank you
Message 11 of 14
Guru
Re: RBR850
Good. Hopefully that's all that's needed.
I would have the ISP help you disable all Wi-Fi radios on the ISP Modem since your going to be using the 850 series for your main Wi-Fi system. Having two Wi-Fi systems can cause interference problems.
Message 12 of 14
gwoit
Re: RBR850
thank you
Message 13 of 14
Guru
Re: RBR850
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 884 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
