Orbi WiFi 7 RBE973
Reply
RBRE960 - 10 Gbit/s IPS but only 500-700 mbit/s over wifi. Normal?
Riversight
Follower
The advertisement for wifi 6e says I should get a way higher speed. Did they get me with misleading advertisement, or is something wrong with my system?
Message 1 of 3
Guru
Re: RBRE960 - 10 Gbit/s IPS but only 500-700 mbit/s over wifi. Normal?
What device are you testing on and how far from the router/satellite are you?
Its usually the device you test with that is the bottle neck. Plus speeds for 5ghz/6ghz (especially 6ghz) drop of quickly with distance/obstructions
Message 2 of 3
Guru
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 399 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
