Orbi WiFi 7 RBE973
Reply
RBRE960 loT displaying under Wi-Fi connections
Tajee
My installer said the the SSID ORBI14-IoT would disappear a few hours after install of the system. It’s been 24hrs and still is listed under my wifi choices. What is this and should it be listed? My main Wi-Fi is ORBI14.
Message 1 of 4
Accepted Solutions
CrimpOn
Guru
Re: RBRE960 loT displaying under Wi-Fi connections
The User Manual on page 64 describes how the Internet of Things (IoT) WiFi SSID can be controlled by the user.
https://www.downloads.netgear.com/files/GDC/RBKE963/RBRE960_RBSE960_UM_EN.pdf
Nothing is going to happen "automatically".  You, as the owner, can use the Orbi admin interface to control the router.
Message 4 of 4
All Replies
iyang
NETGEAR Expert
Hi @Tajee ,
What's IOT devices do you use ?
Thanks
Message 2 of 4
Guru
The IoT SSID always broadcast unless it's disabled by you.
Message 3 of 4
CrimpOn
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 581 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
