Orbi WiFi 7 RBE973
Reply
RBRE960B Just one Ethernet port acts weird
Contz
Tutor
Hi there,
I've this system from Feb now. It works great. I've a Xbox Series X and a Playstation 5 attached to the main base.
Just one ethernet port seems to act strange.
Both with Ps5 and Xbox Series X it basically connects to the internet but the both PlayStation Plus or Xbox Live don't work. If I change the ethernet port they work. But that one doesn't...
What can I do?
THanks
Orbi AXE11000 WiFi Mesh System (RBKE963B)
Message 1 of 15
Contz
Tutor
Re: RBRE960B Just one Ethernet port acts weird
Let me also add that the port acting strange is the 2.5 one. Worked perfectly till yesterday
Message 2 of 15
Contz
Tutor
I got it.
The problem is the firmware.
I set the router back to the 6.0.3.85 and now it works.
Fact is I cannot block autoupdate 😞 and it updated to the new software overnight. Is there a way to block the autoupdate completely?
Message 3 of 15
Guru
For the 2.5Gb port to be used optimally, it's recommended to use the 1Gb ports for the game consoles as they are only 1Gb supporting. They would not get any benefit from using the 2.5Gb port. 2.5Gb port works on current and new FW. I have mine connected and running my RBSs.
Also be sure that when you do use the 2.5Gb LAN Ports on the RBR or RBS, it's recommended to use CAT6A STP cabling as higher speeds can be effected by noises from external sources where shielding isn't not present in UTP cabling. I use CAT6A STP cabling on the 2.5Gb port and lines out to the multi gig switches and out to the RBS.
You can only block FW updates on the newer version of FW.
Message 4 of 15
Contz
Tutor
7 months in nothing happened before the new firmware arrived.
I can’t avoid using the 2.5Ghz because I need all of them.
The cables are ok.
the only way has been to use nextdns and block netgear update servers.
Message 5 of 15
Guru
Funny, new FW works for me and my 2.5Gb ports.
2.5Ghz or 2.5Gb?
Again, to get good use out of 2.5Gb ports and make sure all works, CAT6A STP cables are recommended.
One can connect LAN switches up to the RBR for additional ports when needed.
Also a factory reset and setup from scratch would be needed if you see problems.
Good Luck.
Message 6 of 15
Contz
Tutor
Listen, why the fault should be on my side?
When there is a buggy firmware, works for you on PlayStation Plus/store and Xbox Live?
Otherwise as said it works for me too.
Message 7 of 15
Guru
Well I set my 9 series up yesterday in AP mode for my needs with v6.3.7.5 loaded back in October.
I connected my xbox series X to the 2.5Gb port on the RBR. Left the RBS wireless connected.
I gamed for 4 hours last night with out a hitch on MW2 2022.
Message 8 of 15
Contz
Tutor
Don't know what to say.
Lucky you.
Now it's not working again on my side since the firmware auto updated.
Message 9 of 15
Contz
Tutor
still same problem
the router auto updates itself anyways
ive changed cables, I ve connected my new LG C2 tv and even with that it cannot access its own apps or view netflix content or any other ott.
Message 10 of 15
iyang
NETGEAR Expert
Hi @Contz ,
I want to check more detail for "PlayStation Plus or Xbox Live don't work".
Can't connect to PlayStation Plus or Xbox Live ?
or can't play game in PlayStation Plus or Xbox Live ?
or other problem ?
Thanks
Message 11 of 15
Contz
Tutor
When connected to that port, weather it is Xbox, Playstation, Steam Deck or LG OLED they can detect internet correctly but none of their services then work.
Message 12 of 15
iyang
NETGEAR Expert
Can you share the error page from Xbox or PlayStation ?
Thank you~
Message 13 of 15
iyang
NETGEAR Expert
Hi @Contz ,
What's FW version do you use ?
Thanks.
Message 14 of 15
Contz
Tutor
The latest available
Message 15 of 15
Top Contributors
Discussion stats
  • 14 replies
  • 1515 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
