Orbi WiFi 7 RBE973
Reply
RBS350 is always pulsing white and not connecting to the router
Starani
Follower
I tried all syncing syncing options like reset, firmware update and pressign sync button for 2 minutes.
My RBS 350 is not syncing with RBS350 router and always pulsing white.
I am starting to give up. Network map is not showing the satellite at all.
Please help!!
many thanks
Shayanki
Message 1 of 2
Guru
Re: RBS350 is always pulsing white and not connecting to the router
What Firmware version is currently loaded on the RBR and RBS?
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Ethernet connect the RBS to the back of the RBR get any IP address for the RBS?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 211 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
