- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBS850: I updated my RBR850 firmware before my RBS850 satellite and now can’t detect my satellite
- Mark as New
- Bookmark
- Subscribe
- Permalink
What do I do to detect it again?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS850: I updated my RBR850 firmware before my RBS850 satellite and now can’t detect my satellit
Download the previous firmware from the support web site.
Manually load the previous firmware to the router.
Then reboot.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you. I'll give it a try this evening when I'm done working.
I should have mentioned that I also pressed the factory reset button on the satellite (using a paperclip). Do you think this could impact your suggested solution?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The key is to get the router and satellite to link up again on the same firmware version. If they do not, then it may be necessary to perform the "Add Orbi Satellite" process and then manually update the satellite firmware before updating the router firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If the root of the problem is that the router is on a different firmware release than the satellite, then restoring the ability to connect requires having them both on the same firmware version.
This may be why Netgear's advice is to update the satellite firmware first. The logic seems to be:
- When they are both on the same firmware, they can communicate so the router can push new firmware to the satellite.
- When the satellite reboots after updating firmware, it can no longer communicate.
- Updating the router firmware means that after it reboots they are both on the same firmware release again and can communicate.
Please note that people on the forum are not Netgear employees and certainly not Netgear software engineers. If I had been the person implementing this system, I would not have wanted it to be so easy to create a situation where the customer can no longer access the satellite at all, for example to learn which firmware was actually on the satellite. I have no idea if the Netgear engineer intended it to work this way, or if our understanding is even accurate.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't understand why this would be allowed to happen either. Very frustrating.
I really appreciate your help.
Anyway, I did as you suggested:
I switched to the previous firmware on my router (7.2.6.21), but the satellite was still not detected.
I then unplugged the satellite and plugged it back it in and the white light started blinking.
I pressed 'Add Orbi satellite' and the light started continued to blink but never became 'solid white' as it said it should.
I pressed the sync button on the back anyway and then on the screen.
After a minute or so, the light on the satellite turned solid blue indicating a good connection, but then the screen said satellite setup failed.
When I went to see if it was detected on the orbilogin.com page, it was still not there.
I repeated this last one again with the same results.
I then remembered that I skipped (at least one?) firmware update previously, so I changed to an older firmware on the router (4.6.14.3).
I then ran through the add satellite again and again there was no solid white light but I tried to sync anyway, and this time it said satellite setup successfully. After the blue light went out, I looked at the orbilogin home screen and it still wasn't in the connections or firmware update list.
I repeated this with the same results.
I rebooted the router, tried syncing again, but this time the syncing failed.
Perhaps I was on an even older firmware, which I will try tomorrow...
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Orbi web interface does not update instantly. (sigh. It's a computer, right?)
If the satellite LED turned BLUE, it might be worth getting a glass of (whatever beverage) and singing Mary Had a Little Lamb, and then refresh the Attached Devices page.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I refreshed the device page several times over 30 minutes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I hate to bring religion into this discussion, but it sure sounds like purgatory to me!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you were able to downgrade the RBR back to v4 and the RBS synced, you should now update the RBS to v.21 FW using the RBS web page to manually update it, then update the RBR lastly to v.21.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
