- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBS850 Satellites bricked after downgrading from 4.6.7.5
- Mark as New
- Bookmark
- Subscribe
- Permalink
I installed 4.6.7.5 but was having issues with dropped connections and occasional satellite reboots. I downloaded 4.6.3.16 from the support page and manually downgraded the satellites followed by the router. There wasn't any indication that the downgrade failed on the satellites. Once the router restarted, I loaded a backup of my config from before the 4.6.7.5 upgrade and it seems to be working fine. The satellites, however, all appear to be stuck in a reboot loop. They power up, but the LED continually flashes white. The sync button does nothing, a factory reset did not change things. Is there anything else I can try?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS850 Satellites bricked after downgrading from 4.6.7.5
Try hardwiring them into the router and leave them for a few minutes. then try syncing them hardwired.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@KMDonlon wrote:
This worked for me:
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
Thanks, that was going to be my next step if nothing else works. I'm kind of hesitant to attempt to update the firmware when it is rebooting every few minutes, though.
I tried hardwiring a satellite to the router, same result. It is getting an IP and I can occasionally pull up the admin page, but it reboots before I can do anything.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@plemans wrote:nmrpflash can sometimes be easier to use.
https://github.com/jclehner/nmrpflash
Thanks, I'll give that a try this afternoon. Following NetGear's instructions for TFTP did not work, I just get a "Connect request failed" error. I was watching the status of my PC's ethernet connection to the satellite while attempting the update and it alternated between connected and not connected, so I'm not sure it's staying up long enough to even perform an update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
nmrpflash successfully flashed the firmware, but after rebooting the satellite I'm back where I started. I've noticed the power LED on the back goes from solid green to solid red and then back to green, I'm not sure what that indicates but I'm going to guess it's bad.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also, which firmware did you flash? I downgraded (via side loading) to V4.6.3.16
and got it to boot with no issues. Did it a few times as a matter of fact after messing around with the 2 higher versions floating around here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@KMDonlon wrote:
So you don't eventually get a blue light on the satellite after you restart it?
No, the status LED pulses white and the power LED sporadically goes to red then back to green. This goes on indefinitely on all of my satellites.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What browser did you use to send the RBS FW File?
Possible the RBS nvram or boot parition got corrupted somehow. If TFTP or NMPFlash doesn't recover it fully, I'd contact NG support and ask about RMA options.
