- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBS850 Wired Backhaul - Out of Sync Satellite / Chromebook Connection Issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBR850 connected to 4 wired RBS850 satellites. One satellite continues showing up as "out of sync" - no devices are able to connect to its wifi, either.
Further, two chromebooks that get heavy use near that satellite experience internet drop outs - the signal is showing as strong or medium strenght, but the Chromebook loses internet connectivity.
Any connection between these two issues?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS850 Wired Backhaul - Out of Sync Satellite / Chromebook Connection Issues
Are all RBS wired directly to the RBR or is there a LAN switch in between the RBR and RBS? I there is a switch,
What is the Mfr and model# of the ethernet switch in the configuration?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://https://https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Power OFF ALL RBS. Power ON the one problem RBS to see if it correctly syncs.
Try swapping this one RBS with a known working RBS to see if the problem follows.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nothing new but noticed some real crappy connectivity with the newer Chromebooks (Galaxy 2020) and Acer 713.
3.2.16.6.1.4.4 around the horn for FW.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try changing the CTS value to 2347 Under Advanced Tab/Advanced Settings/Wireless Settings
If not, try disabling AX mode. Seen some posts that chromebooks don't like the AX mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Was already on 2347.
I'll try rebooting Verizon router, and in turn the Orbis, see if all satellites can stay in sync and go from there i guess. Would rather not disable ax, but i guess when it comes down to it the only wifi-6 devices i have are the chromebooks so if i disable ax everything else will be unaffected right?
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
