- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Rbk752 support orbi voice rbs40v
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recently purchased a RBK752 and found a deal on the Orbi voice Rbs40v so I thought I would give it a try. Today I was told that the new Wi-Fi 6 routers do not work with Orbi voice. Does anyone know if the support is coming? If yes I would consider keeping it. If was coming soon
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Rbk752 support orbi voice rbs40v
It's not compatible at this time there has no information on if or when Orbi AC RBS will be made compatible. If it has a LAN port, then you could connect it to the 7 series Orbi that way. IF not, then it's up to you to keep it or not.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hopefully they will. Something to post about here:
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
@JPBOLDY wrote:
The orbi voice is a brilliant satalite, netgear need to make it compatible as people won't upgrade otherwise
- Mark as New
- Bookmark
- Subscribe
- Permalink
In today’s products they always support backward compatibility of older WiFi standards and this should not be any different.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well with the radios supporting different AX modes and such, there maybe some incompatbilities. There is some differences between AX and AC Orbi. IF a RBS is wired, then any wireless device connected to the RBS will appear as a wired device since the main backhaul is wired, not wirelss, so the status for any device on that line will appear as wired.
AX is still new and may have some incompatbilities. You may want to either return the RBS40v or return the Orbi AX system for a Orbi AC system which is more compatible with RBS AC.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here is reply from netgear via Facebook messenger
Hi Jonathan - Thank you for reaching out. The Orbi Voice Satellite works with Orbi AX in Extender Mode. Here's a reference of how to set it up: https://kb.netgear.com/000061427/
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good to hear. Thanks for sharing. Hopefully this helps users with the RBS40v.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for this post. I have the same setup, migrating from an older AC to an AX system I picked up from Costco. However, I had recently added an RBS40V to increase coverage to my former AC mesh network. I want to be able to use the RBS40V in some capacity with the new AX system. I understand that it cannot connect in Orbi mode so changed it to Extender Mode.
All of this worked as documented but then came the confusion. In order to configure the Alexa features of the RBS40V, you need to use the mobile Nighthawk app. Using a desktop web browser allows the network setup of the RBS40 in Extender Mode, but you cannot access the Voice Controls. Even then, you may need to quit and reopen the Nighthawk app to get the Amazon Alexa login.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for posting this additonal informatin. Hope this helps.
@geewhy wrote:Thanks for this post. I have the same setup, migrating from an older AC to an AX system I picked up from Costco. However, I had recently added an RBS40V to increase coverage to my former AC mesh network. I want to be able to use the RBS40V in some capacity with the new AX system. I understand that it cannot connect in Orbi mode so changed it to Extender Mode.
