Orbi WiFi 7 RBE973
Reply
Re: My Orbi RBRE960 and RBRS960 network will sometimes just drop the wifi networks
Emilio142
Follower
I have the exact same problem. Used the set first in the regular router mode. Thought that the router mode was causing the problem as my internet provider uses a modem that cannot be set to bridge mode. Happened at least once or twice a day. Sometimes around the same times although never exactly at the same time. Switched to AP mode as I saw that this fixed the problem for some people. Although it is happening less often it still happens almost daily.
I have one base and two satellites. 3 floors to cover. The base is on the first floor, 1 satellite on the ground floor and 1 on the top floor. The satellites are connected through a wired backhaul using a "dumb" switch.
Only 1 router won't cover the entire house because we use reinforced concrete and double laminated glass in our houses. Great for structural integrity and insulation but it is really bad for wifi or other radio signals.
I do have a lot of neighbours who are directly adjacent to my house with also very strong WiFi signals.
I used to Orbi app to get a good idea of strengt of the different wifi signals.
Anyway the wifi signal will drop randomly. Sometimes the sattelite led will glow purple/magenta and then go back to blue and then turn the led off. Sometimes it doesn't happen and the wifi will turn back on after a couple of minutes.
It is really annoying, especially during meetings when working remote.
If it's a bug I hope they fix it with the next update
Message 1 of 3
Guru
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
What channel configurations are currently set on the router?
How are the RBS ethernet connected to the RBR? Using which ports on the RBR and RBS for the ethernet connection?
What is the brand and model# of the non managed switch in the mix?
What CAT# LAN cable is being used? CAT6A STP is recommended for 2.5Gb ports being used.
Message 2 of 3
Guru
Any progress on this?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 260 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
