Orbi WiFi 7 RBE973
Reply
Re: Orbi WiFi 6 (RBR850) Backhaul Status Out of Sync w/ Satellite (RBS750)
paras_waiba
Follower
RBS Satellite 'out-of-sync" problems I got this resolved just by going to Advanced tab and under "Firmware update" then choose "Manual update" choose the RBS750 Satellites and do the latest FW update and then my out-of-sync issues was resolved.
No need to reset to factory settings as some have suggested.
In case nothing works then I would recommend factory reset and doing FW updates.
Message 1 of 2
Accepted Solutions
Guru
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Message 2 of 2
All Replies
Guru
Enjoy. 📡
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 407 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
