Orbi WiFi 7 RBE973
Reply
Re: Possible solution for Orbi dropping connection (when connected to satellite)
RonBZ
Follower
Yes it was turning off Access Control that stopped my RBS350 from constantly reconnecting. After 2 years same fault still exists.
Message 1 of 2
Guru
What Firmware version is currently loaded on the RBS?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What model RBR is the RBS350's connected too?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 721 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
