SLJ1000's avatar
SLJ1000
Follower
Oct 07, 2023
Replacing Google mesh with Orbi RBR850 resulting in “No Internet”
I am replacing a working Google Mesh with a brand new Orbi RBR850. It was a rough install needing to “retry” almost every step. Got to the end then internet spotty culminating to “no internet”. Put the Google mesh back on and the internet is fine.
I use a NETGEAR CM1100 Cable modem.
Any solutions to get the Orbi working??
1 Reply
  • FURRYe38's avatar
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Be sure your using WAN port #1 on the CM modem and the other port is not used. The other WAN port can be used by the ISP if they support having two WAN IPs. Most ISP only support 1 WAN IP address.
