Orbi WiFi 7 RBE973
Reply
Restrict Connected Devices to Satellites Only?
steven_b
Follower
Hi All,
I am running an RBR350 Router with 2 Satellites.
As the router is in the garage and my teenagers are above and next to it, can I restrict them to connecting to the satellites in the main house only?
If not, would they be getting priority where speed/bandwidth is concerned? I figure the signal sent to the satellites from the router could be weakened if there are other devices directly connected to it.
I am at the other side of the house and work from home in graphics so would rather priority coming to me during the day, weekdays.
Steve
Message 1 of 2
Guru
Re: Restrict Connected Devices to Satellites Only?
No.
Try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 202 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
