× You're Invited! Orbi RBK763 Beta Firmware Testers Needed. To participate in testing this trial firmware, please click HERE.
Reply
Router Software
phildeman
Follower
Router Software
Hi,
I just installed an Orbi WiFi AX4200.  During setup, an external device connected to my router, while I was setting up Access Control.
I have blocked the device to prevent further access.  However, I wanted to remove the device from the Access Control List.  There is no option to remove devices from this list.
If I manually added a device to the "View list of allowed devices not currently connected to the network" section, I can remove the device if I choose to at a later time.  However, I can't seem to remove the device from the main Access Control list.
Is there a way to remove devices from the main Access Control list, besides simply blocking the device?
Thanks.
-Phil-
Message 1 of 2
Guru
Re: Router Software
I believe the list populates by what ever gets connected and detected by the RBR. So it just displays what is connected to the system for users to select that can be controlled by the user and system.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 245 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
