- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Router continually reassigning IP addresses to the satellites.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm also having this issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Router continually reassigning IP addresses to the satellites.
Please edit out any MAC addresses or product serial numbers before posting in public forums for security reasons.
How are your RBS connected to the RBR, wireless or wired?
How many RBS do you have connected?
Is Armor, SPC, or Traffic Meter enabled?
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware version is V4.6.8.5_2.1.9
Home size ~6500 Sqft
Traffic meter enabled, no limiting
FIOS ONT
1 RBR850 + 1 RBS850 connected via wired backhaul.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is the RBS directly connected to the back of the RBR or is there any LAN patch panel and LAN switch in between?
What CAT# cable are you using between the RBR and RBS? CAT6 is recommended.
Have you set up an IP address reservation for the RBS ON the RBR?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Two switches in between, both showing 1 gbps connection with lights, confirmed with speed tests getting ~900mbps download/upload. Cat 6/7 used with all connections.
**Oops. Yes, RBS is set to 192.168.1.2 and maintains that reservation.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the Mfr and model# of the ethernet switch in the configuration?
Other than duplicate IP address assignments, is the system working ok?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Both are Netgear. One is a dumb switch, the other is ProSafe. The IP reassignments seem to correlate with wireless devices getting dumped off the RBS and not being able to reconnect for a while. But not all devices and never the wired devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the model# of the ethernet switch in the configuration?
What is the current CTS value seen on the RBR? Under Advanced Tab/Advanced Settings/Wireless Settings
Try lowering the transmit power on the RBR from 100% to 50%. Under Advanced Tab/Advanced Settings/Wireless Settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
Distance between them is probably 30+ feet. RBR is in the basement and RBS is on the 3rd floor. CTS is 64. Is it possible to lower the power on the RBR alone and not affect the RBS? I have a few places in my house that don't have great coverage already.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try it can see. You can always put it back.
Seems like devices maybe ping ponging back and forth thus causing these IP addresses. Its up to wifi devices to pick and choose where they connect to and maybe hopping around trying to get connected to one signal source.
Basement is not recommended location for the RBR. Even if the RBS are ethernet connected.
• Yes! WiFi 7 is backwards compatible with other Wifi Devices? Learn more
