Orbi WiFi 7 RBE973
Reply
Since firmware update - new network map?
donawalt
Virtuoso
See attached picture - I have two wired RBS850s and an RBR850 router. Since the update to 4.6.7.13 yesterday, it shows the 3rd floor router into the satellite into the router. Before, it showed both satellites to the router directly. What is odd about this is both satellites are hardwired into a switch into the router, so is this really true?
Message 1 of 6
Accepted Solutions
donawalt
Virtuoso
Re: Since firmware update - new network map?
I power cycled the satellite on the first floor, left it off for a c ouple of minutes - that fixed it. I was guessing the 3rd floor satellite would then connect direct to the router while the other satellite was powered down, which it did according to the map. I still wonder why, when both satellites are direct connected, it showed one satellite connected to the other instead of to the router?
Message 2 of 6
All Replies
donawalt
Virtuoso
Message 2 of 6
Guru
when it happened, did you ever check it through the browser or was t hat through the map?
It wouldn't be the first time the app didn't display something appropriately. But the photo does show the hardwire connection.
Either way since its resolved, you can mark it solved so others aren't still trying to fix it 🙂
Message 3 of 6
Guru
So a screen capture of what it looks like after the power cycle would be nice.
Message 4 of 6
donawalt
Virtuoso
It was through the App. I forgot to check the web browser, sorry.
I'll mark it resolved. Here is a screen cap of the final:
Message 5 of 6
Guru
Enjoy. 📡
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1043 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
