× You're Invited! Orbi RBK763 Beta Firmware Testers Needed. To participate in testing this trial firmware, please click HERE.
Reply
Slow RB850
RSPS1
Follower
Slow RB850
I have a new AX6000 with the router and satellite on opposite ends of the house. The house is fairly small, 2400 sq. ft. At the satellite end a wifi strength meter says very high speed, but when I try to download to a devce it says slow connection.
Message 1 of 2
Guru
Re: Slow RB850
What device are you using at the RBS?
What are you trying to download to this device?
Is Armor enabled on the Orbi RBR?
What happens if you connect to the RBR?
I recommend that you need additional help, you should find a nieghbor, friend or family member to help you out with this.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 223 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
