× You're Invited! Orbi RBK763 Beta Firmware Testers Needed. To participate in testing this trial firmware, please click HERE.
Reply
Slow download speeds wired and wireless Orbi 753
sean10780
I have really slow download speeds on my Orbi 753 i just purchased from Costco. I am running firmware V3.2.16.6_1.4.4. I have att fiber running on a pace 5268AC. I have all the router components disabled on the ATT modem and the orbi 753 set as a DMZ plus device. If i turn the Orbi 753 into an AP mode and use my old RBK53 as the router then everything works fine. I even went back to Costco and exchanged it for a new one so there seems to be something wrong with the router and my internet. Can someone help?
Message 1 of 4
Guru
Re: Slow download speeds wired and wireless Orbi 753
Seen other posters taking about the PACE modem being a cause of some problems.
https://community.netgear.com/t5/Orbi/Installing-Orbi-behind-ATT-Pace-5268AC-gateway/td-p/1234191
https://community.netgear.com/t5/Orbi/Netgear-Orbi-and-ATT-Pace-5268-Router/m-p/1786833/highlight/tr...
What happens with the modem in router mode and the RBR in wired mode and no DMZ on the modem?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router RBK963 and RBK853 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 4
sean10780
So if I have the 753 in router mode and get an ip from RBK53 who is serving as my DHCP then I'm still getting the slowdown speed. If I put the 753 in AP mode and static an IP from the RBK53, then the speeds go back to normal.
Right now I have my RBK53 in router mode and ATT Modem in DMZ pass through mode with firewall disabled and the WAN port shown in the RBK53 and it works great. If I replace this existing RBK53 with the 753 AX then the speeds are slow.
How can the RBK53 work and the 753 not?
Message 3 of 4
Guru
Try a factory reset on the 7 series behind the ISP Modem and walk thru the setup wizard. Don't enable Armor, QoS speedtest or traffic meter. Go right in and use a wired PC and speed test with Ooklas installable speed test app. If this still fails, either return the Orbi AX for another or make contact with NG support.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 479 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
