R_Noodle
Sep 01, 2022Follower
Starlink & RBR760 question
StarLink is my ISP feeding my RBR760 — Orbi Tri-Band Mesh WiFi 6 Router. My StarLink system has a hardware issue and is in the process of being replaced. When I get the new hardware (dish & router), will I have to do a full reinstall of the RBR760? If a full reinstall is required, would the process be to use the Orbi application to "Set up a new Orbi System"? Thanks.
1 Reply
Try first powering OFF the RBS and RBR. Connect the new ISP modem to the RBR. Power ON the modem and wait for it to come to ready, then power ON the RBR and wait for it to come to ready. Check internet services here with PC or wireless device.
Refer to the ISP support and additional information regarding use of there equipment with external routers.
