Orbi WiFi 7 RBE973
Reply
Status/Firmware Upd shows 1 Satellite - but there are 2 connected
z8
Guide
Guide
I have a RBK853 system (two satellites). One is wired, one is wireless.
On the main page it says I have one satellite (the wireless one) and when I try and check for new FW it only shows one, but on the devices page I can see both satellites. How do I get the main router to properly recognise the other (wired) satellite?
Using V4.6.3.16_2.0.51 and the router is in AP mode.
Message 1 of 11
Accepted Solutions
z8
Guide
Guide
Re: Status/Firmware Upd shows 1 Satellite - but there are 2 connected
That didn't help, but thanks for the suggestion - it made sense to test that.
In the end (in desparation) I factory reset the whole thing - satellites, main router, the lot.
And now it works.
Message 10 of 11
All Replies
z8
Guide
Guide
Message 2 of 11
z8
Guide
Guide
This only happens when it's wired.
If I disconnect the hard wire and connect it wirelessly, then there's no problem at all and it shows two devices.
Message 3 of 11
Guru
Is the wired RBS directly connected to the back of the RBR or is there a LAN swtich in between the RBR and RBS?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 4 of 11
z8
Guide
Guide
There's a switch - but there always has been.
I switched the main device from Router to Access Point, and this has occured ever since.
Message 5 of 11
Guru
What is the brand and model# of this switch?
Message 6 of 11
z8
Guide
Guide
The satellite works .. it's just not detected on -some- of the screens of the main router.
It is on the devices page, though.
Message 7 of 11
z8
Guide
Guide
The switch is a Netgear GS308
Message 8 of 11
Guru
What do you see if you remove this switch from the mix and a quck test? Directly connect the RBS to the back of the RBR?
Message 9 of 11
z8
Guide
Guide
And now it works.
Message 10 of 11
Guru
Glad the reset worked, was going to be my next suggestion.
Please mark your thread as solved so others will know.
Enjoy.
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 1004 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
