- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Suddenly I can not access forwarded public IP:port (web site) using Orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi friends here
I've been using my Orbi RBR750 since last year, and I've set up a port forwarding to expose a hobby website from my PC (192.168.1.123), so for external users, they visit http://public_ip -> http://192.168.1.123.
It works well. However, since the last firmware upgrade, I found myself unable to visit https://public_ip under Orbi's wifi.
- If I turn off wifi on my phone, I can still access http://public_ip using the mobile network.
- If I turn on WIFI on my phone, I can only use http://192.168.1.123 to access my site.
It is pretty annoying as I WFH most of the time. Does anyone know how to fix this? Thanks in advance.
PS, I do have ddns setup but I track it down and found it does not work on the IP address level.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Suddenly I can not access forwarded public IP:port (web site) using Orbi.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
@mikemike2022 wrote:Hi friends here
Gooid bug report. NAT Loopback, i.e,, also being able to use your public DNS/IP from within your home network, is supposed to work on the Orbi RBR750 series: https://kb.netgear.com/000049578/Which-NETGEAR-routers-support-NAT-loopback?article=000049578.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The feature involved is called NAT Loopback, and is claimed to work on the Orbi RBR750:
It would be a useful experiment to manually load the previous firmware on the router and then quickly test NAT loopback (before the router has a chance to 'auto update' itself. If NAT loopback works as it used to with the previous firmware, then it would seem that Netgear has broken NAT Loopback with the firmware update.
Have you tested NAT Loopback using a device connected to the Orbi with Ethernet?
This issue would not seem to be connected to a possible DDNS problem. It would take more detail to understand that issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi FURRYYe38, here are my version info
Hardware Version RBR750
Firmware Version V4.6.5.14_2.0.54
GUI Language Version V3.0.1.2_2.1.30.3
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
You might update FW, factory reset and setup from scratch and see if this problem continues:
• Yes! WiFi 7 is backwards compatible with other Wifi Devices? Learn more
