Orbi WiFi 7 RBE973
Reply
Switch for Orbi AX1800
Obiwanfiobi
Follower
Hi can I use a ethernet switch with this model wifi6 router? I'm not technical-minded so is there any specs I need to tell the electronic store?
Message 1 of 2
Guru
Re: Switch for Orbi AX1800
Yes,
NG GS-105/108v4 and GS308v3, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems.
Be sure to use good quality CAT6 lan cabling.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 250 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
