Orbi WiFi 7 RBE973
Reply
TrueNas time machine backups failing over Mesh Network only
tnine
Hello,
I'm having a somewhat weird issue I could use some help with. I'm running TrueNas version TrueNAS-12.0-U7. I'm using an SMB "Mutli-protocol AFP/SMB Shares" as a time machine backup. When I have the following network setup, I'm able to back up to the time machine mount successfully. The lines with arrows indicate a wired connection
Laptop --> Netgear Orbi Main Router <-- FreeNas
However, if I have the following network setup, I'm unable to back up via time machine.
Laptop --> Netgear Orbi Main Router ---- Orbi Sattelite <-- FreeNas
What's odd, is that in the 2nd network configuration, I can browse the shares over the network from my laptop, but I can't seem to mount the time machine encrypted disk image over the network via Finder. It doesn't seem to be a physical connectivity issue for any other connection interface. The time machine just refuses to back up with the generic error message.
This seems to be a bug in lower level mesh network of my RBR850 hardware, since if both devices are wired to the same satellite, the issue does not occur.  Does anyone have anything I can check?  All of my satellites and router are on the latest firmware version. V4.6.3.16.
Thanks!
Message 1 of 8
Accepted Solutions
Guru
Re: TrueNas time machine backups failing over Mesh Network only
Message 7 of 8
All Replies
Guru
How is the RBS connected to the RBR? Wireless? Any chance you can try connecting the RBS via ethernet as a quick test?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy... 📡
Also you might review this:
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-v...
Message 2 of 8
ekhalil
Master
- Is Orbi operating in router or AP mode?
- What are the IP addresses assigned to the laptop and the FreeNAS?
Message 3 of 8
tnine
So it seems setting up the system in the Star topology doesn't resolve the issue.  When I view the firmware versions in management UI at http://orbilogin.com./start.htm , it doesn't show the firmware version you've linked to as an update option.  Is the linked version an early release version of the firmware?
The Orbi is operating in router mode.
The NAS has a static IP assigned of 10.10.0.10.  My CIDR range in my LAN is 10.10.0.1/24, and my DHCP leases start at 10.10.0.20 to 10.10.0.254
Thanks for the help!
Todd
Message 4 of 8
Guru
Is there a router in front of the Orbi router? Usually the RBR runs 192.168.1.1/24.
Message 5 of 8
tnine
No, there is no router in front of the Orbi.  In fact my ISP has assigned me a static IP. As a result my WAN has a static IP, and I've simply changed the addresable space on the LAN to a different class A subnet that requires less typing 🙂
Message 6 of 8
Guru
Message 7 of 8
tnine
Upgrading to the latest firmware seems to have resolved my issue!
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1033 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
