Orbi WiFi 7 RBE973
Reply
Turn off WMM advisable?
donawalt
Virtuoso
I was wondering - I have had WMM enabled on both my Orbi 850 and 960 for a long time. But now, with the 960 I am on a 2G Comcast plan. Since WMM is basically prioritizing video/audio over other traffic, and with a 2,5G pipe, should I turn off WMM? The other reason, I thought I have seen that with WMM off, WiFi performance improves - which is logical if audio/video is being prioritized higher.
Thoughts?
Message 1 of 9
Guru
Re: Turn off WMM advisable?
It's recommended to keep that enabled for 2.4Ghz devices. Though if your not really using 2.4Ghz, I suppose you could disable it. User option.
Message 2 of 9
donawalt
Virtuoso
Hmm. I have smart plugs, a Ring doorbell, and Harmony Hubs for TV remotes that all use 2.4. So I guess I shouldn't....
EDIT: I forgot - NG doesn't let you have access to WMM in the 960 anyway...
Message 3 of 9
Guru
Something to try, I can only see the Ring Door Bell maybe needing bandwidth. Hubs and devices that don't need much or lots of bandwidth wouldn't have a need for any WMM QoS processing as I presume some of these devices have intermittent usages or data flow.
Message 4 of 9
donawalt
Virtuoso
The Ring does have a 5MHz radio too, but it doesn't use it very much.
I posted it as an edit, but I don't think the 960 admin age lets you change WMM for either band any more..?
Message 5 of 9
donawalt
Virtuoso
Wow doing some looking around, this is weird - if I look through all the router admin web pages, I don't see WMM. But if I go direct to this page
http://orbilogin.net/QOS_main.htm
it's there!
What other hidden pages are there?
Message 6 of 9
Guru
Does that page work after you select it and apply the change?
I'll check mine and see. I know it's still visible on the 850 series last time I looked.
What browser are you using?
Message 7 of 9
donawalt
Virtuoso
I didn't want to change it, in case it messes something up. I suspect they took the "QoS setup" link off the Advanced/Setup sidebar, that's where I the it was on the 850.
I checked the router admin page on both Safari and Chrome, not there for either.
Message 8 of 9
Guru
Possible removed for the 960 series. 🙄 I'll check mine again.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 344 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
